Root Lg ally support for Android-wifi-tether in testing!
mattrb
Member
The power of drellisdee is strong. His effort has brought a custom kernel with ext and android-wifi-tether. The link is not public on the android-wifi-tether google code page so don't look there yet.
Link: http://android-wifi-tether.googlecode.com/files/wireless_tether_2_0_5-pre9.apk
Please test by getting drellisdee's kernel and the unreleased tether app.
Notes:
The kernel needs rom support for app2sd to work with drellisdee's kernel.
This is better then barnacle because it supports more devices and is open source.
Dosent work for me.
I have his kernel and Velocity. It starts fine but when I try to click the "Start tether" thing it force closes.
Running:
ROM: Velocity 0.1.1
Kernel: 2.6.29 dustin@dustin-laptop #4
Also,
Notes:
Are you informing us that we should be testing it with a ROM that supports Apps2SD? (Dapper Duck)
Or is this just an aside, that Apps2SD doesn't work with drellisdee's kernel unless you also use a ROM that supports Apps2SD?
