When you have had many androids (Not a ton , but tinkered with a lot of them
And have had experience on many versions of android... You start to learn , and you read , and read , and read , and try , and learn , until you get it right! I know it is very hard and time consuming! Me and my friends (They refuse to join the forum for business reasons) Are working as hard as we can when we have the time , I am currently working on apps , One is working on the Interface a bit , One is on Performance , and one is on boot animation , turning off animation , sequence , etc
We all have a job in this and we all work together , Now , Since we are being slowed down (Uggghhh 4th of July , Not a party.... I am usually forced to go to them and "enjoy" it , when I can just sit down with a friend and talk about stuff and phones)
So soon 2-4 weeks (Hopefully) We will have a beta version for people to test out if they wish!
(NOTE - Anything on the beta , DOES NOT mean It will be in the final release , things can change at any time , so don't come to conclusions , since I don't like it when people are like "Look at the screen , it looks like it will get voice search" or something and then "Guess they didn't put voice search into it
" Just a little note/comment...)
If you want , I can put a file apk so you can test some ICS apps (They work on Gingerbread after coding) They have the ICS theme/layout with the blue bared tabs , etc , I can post APKs to 4Shared , Though I am not completely sure about just putting the APK so other people can edit it or copy as their own (Many people do that on 4Shared , It gets hard to find the original)
Also , Reply with a WHOLE LIST of update to ICS Rom if you want it , It will be taken into consideration , Or we can just give you ICS ROM so no optimization and no special upgrades , tell us what you want , and we might do it
