Root LG Connect
Here is what I got from the lg site is suppose to give you the voice over LTE
Cant get it to install in CWM any ideas on what to do?
Open Source Main
Not sure cause for me it downloads as a HTML file at 166mb. So I'm not sure if renaming it to a .zip file would do anything but maybe someone else here will c this and have some info as to what how to get it to wrk 4 u
just downloaded it, looks like maybe source. Inside zip, there is android.tar.gz and kernel.tar.gz.
Taken from the readme.txt included in zip:
1. Android build
- Download original android source code ( gingerbread 2.3.6_r1 ) from Welcome to Android | Android Open Source
- Unzip opensource packages of MS840_GB_android_2.3.6_r1.zip into downloaded android source directory
- And, merge the source into the android source code(gingerbread)
- Run following scripts to build android
$ . build/envsetup.sh
$ choosecombo 1 1 generic user
$ make
- When you compile the android source code, you have to add google original prebuilt source(toolchain)
into the android folder
- After build, you can find output at out/target/product/generic
2. Kernel Build
- Unzip MS840_Kernel.tar.gz at the android folder
- When you compile the kernel source code, you have to add google original prebuilt source(toolchain)
into the android folder.
- Build kernel
$ cd Kernel
$ make cayman_mpcs_us-perf_defconfig ARCH=arm CROSS_COMPILE=arm-eabi-
$ make ARCH=arm CROSS_COMPILE=arm-eabi-
- After Build, You Can find the build image at arch/arm/boot
