L ltot Lurker Oct 10, 2012 #1 The menu key will change the ringer volume with every other time that it is pressed. Please help.
Digital Controller The Real Bass Creator Oct 10, 2012 #2 ltot said: The menu key will change the ringer volume with every other time that it is pressed. Please help. Click to expand... Hey there ltot, i moved your thread to the LG Enlighten forum so that it could better be answered Hope this helps our search for the problem you are having!
Granite1 Zercron Encrusted Tweezer Oct 14, 2012 #3 ltot said: The menu key will change the ringer volume with every other time that it is pressed. Please help. Click to expand... That is a strange one indeed. If it continues, I'd either try a factory reset, or take it back and have it looked at. Your menu key should not be behaving like that.
