Help LG Esteem test mode MNC
Does anyone know the MNC mobile network code for the Lg esteem? I live in Orlando by the way. my phone went into test mode and fuzzys guide isnt really working for me. Can someone take a screenshot of their LGNPST screen when in NAM1 and post it so I can copy my settings to theirs? you can block out your phone # and everything I just need the settings
And I even tried pushing PRL's to it with no luck. I really think its just some settings number value im entering wrong thats why im asking for a screen shot of someones LGNPST settings *_*
Did you enter the right mdn. Min. Sid codes if so you may need to update the prl try to use 3029 and update with *228
Well if you did it all the way he said in the post you would see that the pushing of the prl is a must that's why i said to try a lower one
Ohhhh my goooood I already have all that stuff. I'm just really stressed. I know what I'm doing I just need to know the MNC codes and stuff all I need is a screenshot. That is all. OR if someone has had the same problem as me can they just give me a solution
Yes i have and know the number you can type to put it in test mode ...but when i was in test mode i never had ti mess with the a.p.n ...that mcc is part of the metro internet and that's something u can access through the anycut app
it used to bring up the hidden menu but not anymore because I got it out of test mode BUT I still dont have service or anything just 4g access
Ahhh okay do this as it seemed to work for ppl.
It has happened many times try this ( I posted this in another thread )
1.download Any cut from play store.
2.on home screen try to open a shortcut
3.after you select shortcut select "any cut" (the app) 4.go to activities
5.let it load (it may takes few mins)
6.then scroll down until you see CDMA options (IT HAS TO BE THE FIRST ONE), then select it
7. so now CDMA should been in your home screen, press it and it will restart CDMA or reset the configurations. ( it will foreclose )
8. After that put the phone in airplane mode and then back to normal...
checks if it works
S
