Thanks in advance!There will be once I finish this semester.
I'll write it up for you in a week
That would be great... Especially a working camera on lollipopI found android lollipop source code. I will build that and upload it for you guys here. Maybe the f60 will get android lollipop after all. But first I gotta get through my finals D:
I am on lollipop and can use WiFi tether router with no problems. Camera not working on lollipop though, don't know if that matters to you. Only other issue I've had is with screen rotation on videos, maybe user specific.I'm still using the stock rom 4.2.2 and was wondering if I flashed CM12 if I would be able to wifi tether without problems
Currently I'm using the USB tether method with hide usage 1 on
Also.. The guy I said I'll create a Unix version of the root: I'll get to that tonight or tomorrow. It would be great if you could post the windows root here again so I don't have to search for it again.
Yeah there's a huge difference because cm merged in codeaurora which is qcom open source code which makes support for qcom boards much easier working with aosp means your going to need a lot of work done. It would be easier to work with caf L source but regardless of what L source you use our kernel is outdated GPU and all need updated because it's basically incompatible with the current display hal of google and cm.There's a difference between cyanogenmod and googles lollipop
Didn't see that I'm just getting back into the development game. So I'm downloading that and beginning the merge into the caf based kernel tag which we already identified. I still need to diff all 4 variants kernel source to ensure it supports all variants so far ms395 is the only variant with kernel source for L available.The 1gb package of v20a lollipop does include kernel source for the ms395
Apologies I understand now didn't know they released kernel source. Is the firmware released ? Using L source and kk blobs most likely the camera is still going to be broken.Him. Well lg has provided android l source code. So I'm assuming that kernel is updated. Still downloading the android 5 source from Google. Feels like I'm downloading all the versions (takes for ever)
