wildcard102
Member
APN?
Access Point Name
APN?
I've tried it on unjustified devs 12.1 No apns. Been doing research on it and it's a cyanogenmod bug.
mine will work in the regular recovery but it has two be installed through a rom installer on the phone then it goes into recovery and works fine if I go to straight to recovery it will never work for me I don't know if its my phone or if it's just some kind of a weird bug or whateverI installed mine in recovery with twrp. I've heard mixed opinions about ROM installers.
I've been in this situation before it has to do with the rom no being installed correctly or the wrong rom I did this on my other lg and had to use the kdz but this phone doesn't have a kdz yet so I would just try and install the rom from different placesyeah strange, i am not even getting any data at all. i tried factory reset, added/tweaked various APNS,
when i switch back to CM12 and change some value @ MetroPCS APN, it immediately recognized 4G LTE..
Completely off topic and just out of curiosity but would posting a flashable zip with some of my favorite and useful apps be allowed here?
So, this ROM is still beta?
So... What is it about the camera? I have heard the same issue with other ROMs as well.For me this is as good as daily driver. I am using it now
The only major issue is camera not working. So if you don't need camera, go ahead and use it Data working fine, GPS working fine, phone call / message all work excellent, no major lag or inconvenience at all.
I am actually surprised porting came out as this high quality![]()
The only ROMs currently available for this device are maintained by one person and the problem is the kernel for all the ROMs breaks camera functionality.So... What is it about the camera? I have heard the same issue with other ROMs as well.
I have not seen anyone ask the question: If the ROM you are using/testing has a camera that does not work, can you add something into the mix to get the camera to work?
Speaking of... Can someone "throw up" a link to whatever XDA forum has the ROM folks have been chatting about here? [I've been working backwards through this thread and have not found it yet]Wish we could get a xda forum!
The backup that jack uploaded was lg stock kk. Whatever wildcard said, there's a bug in the 12.1 builds, sure you can edit the APNs on the first boot if your lucky but when you reboot the bug reappears. UD hasn't even made another cm12.1 build alongside his recent cm12 because more debugging is needed. The only difference between the new android update and 5.0 is changes in UI with quick settings and pinning in recent.@Incakola. With jacks backup and with the format , did you get APNs working on cm 12.1?
I used Jack's backup today and data works. Before the restore, i formatted everything using rm-fr protocol in twrp and used only the system and boot partitions in the backups. Lte was already running as soon as boot was complete and the setup was running.
