Help LG G2 D802 Fastboot Problem, Help Please!
efufahad
Hello,
i cant go in download mode, when i enter in download mode it showing me;
fastboot mode started
reset
portchange
reset
portchange
and in device manager u can see it saying Android in unknown device...
i tried installing adb drivers from xda-developers best suggested. but nothings happening i uninstall all drivers and install again wont work again.
Also if i try to follow fastboot erasing and flashing instructions it stucks and nothing happening...
Im using windows7 32-bit
LG G2 D802 Internationl
Country Pakistan
Your help and guidance i will be really appreciated... im worried please help...
Thank you
PDAnet drivers work well for fastboot recognition. No need to install them, they come packaged with the pdanet download and once they live on your machine, they should apply when you plug in device in fastboot mode. Test with fastboot reboot command.
Once you have fastboot working, fastboot flash aboot, boot, dbi, laf, rpm, sbl1, and tz using the img's for your variant:
http://downloads.codefi.re/autoprime/LG/LG_G2/D802/Stock_Firmware
When done, unplug phone, power off entirely by holding power for no less than 15 seconds. Then press volume up while at same time connecting to pc and you should get download mode. Then follow back to stock instructs to flash kdz/tot to finish complete restoration:
http://forum.xda-developers.com/showthread.php?t=2432476
If using kdz method, recommend using the "cse" flash option in the kdz 2014 flash tool as it will wipe and install clean.
If fastboot drivers are installed properly, it'll typically show up as "adb interface" or similar wording in device manager.
