Help LG G2 Not Turning On. Help!!
What should i put for these since i skip step 1.
All I can offer is to make sure all the options and check boxes are the same as seen there. I didn't run into any of the issues you're having. Sorry I can't be more help.
I think it's from the 1st step because the picture from the 1st step he had extract the TOT file and it show that he had the partition.txt
Hey I been trying to figure it out, every time I tried to extract the tot file so it would create the file partition.txt. The Boarddiag like crashes or it will say not responding. Do you think it's because of the tot file? Also if i don't do that step then i can't start the test.
Hmm ok so it seems like you're doing things right. Could be a long shot but I wonder if the program might view the space between Martin Vue causing a broken path of sorts? Idk its a long shot but maybe try moving the tot into a folder on the root of your C drive and then make a 2nd folder also on root of C with a slightly different name as the target folder for the extracted partitions. Make sure there are no spaces in the path. Worth a shot maybe?
Some people seem to be having the most luck on port 10. Go ahead and try flashing on com 10 even though your device shows com 6. If that does not work, try forcing your device into com 10 by going into device manager, right click on device in the ports area, then properties > port settings > advanced and change it to com 10. Let us know how that goes.
Tried it and still didn't work. Boarddiag kept crashing but I did check the folder in my C drive where I put it as dirr to extract it. It had some .mbn files but not partition.txt.
I'll check if the partition.txt still resides on my machine and if so, what it contains. Maybe we can fake our way forward. I wouldn't be surprised if there were a way to move forward with those mbn files already, just not sure which tool options to use.
If you do have the file partition.txt. I wonder if you could maybe upload it and then I'll download it, put into my dir folder. You think that will work?
Idk I'll see what it consists of and maybe we can do that or crack the code and build one that would match your setup. That's IF I still have it on my machine, not at all sure on that. I'm mobile right now so I'll post back when I can.
Iowabowtech, I can see ur kinda know all about this issue. Im having the same thing, phone is just dead. I installed the drivers so it recognises the phone as
Qualcomm HS-USB QDLoader 9008.
Now, even using your board diag exe, when im trying to do the AP check it comes up with an error, that the phone is not in DL Mode.
This is the exact error im getting. Also ive tried doing it on win xp 32 bit in vmware with the same result
Sorry, I was just playing when ive done the screenshot, but tried withouit selected partition and it is the same. Even if I do AP check by itself withot the tests it does the same thing. ( I was looking on XDA to find simmilar issue but nothing)
Hi,
I want to jump into this conversation.
I have managed to get the tool to run as should with help and i'm very grateful for that.
I also got the 3 ok that means that all is fine with the device.
Unfortunately when i connect the phone to the usb / charger my led is blinking red, long pressing the power will turn to led off for 2 seconds and then reblinking again.
In one of my tryouts I've managed to get to download mode for 3-5 seconds, and since then still blinking red.
I heard that it could be the battery fault, and people suggeted me to click volume+ while connected to usb and wait for 3-5 minutes to charge it but it didnt helped, even kept it over night connected to wall charger and once with a rubber taped to the button over night while charging, both methods didn't helped.
Can you help on this?
Thanks,
Nimrod.
