LG G3 boot loop
Help!
My phone since android 5.0 will restart of its own accord
It got worse when it would restart 10 times a day.
I did a factory reset and charged it to about 80℅ tried to unlock it and it restarted about 30 times until it turned on at 1% and died. It restarts multiple times a day and the only way to stop it is to put it on charge. This doesn't always work. It just restarted on charge but doesn't get stuck. It can't be an app because input it in safe mode and it did it straight away.
What do I do I'm going away for 5 days in 3 weeks where all I will have is power packs I don't want it to restart all day.
It also gets really hot and lags afterwards​
Try checking the battery & contacts in the battery compartment for fit & cleanliness.
Also,if you can,troubleshoot w/another battery from the point-of-purchase/service provider.
A loose-fitting battery will cause re-boots,as it's constantly shifting/connecting/disconnecting.
You could also shim-up your existing battery w/a small piece of paper/plastic to ensure full contact w/the battery & contacts.
Basically the battery contacts are a bit scratched I think it does move around. I have ordered another batther but will try what you say. Thank you!
I don't think where I live any service provider will have a battery
I tried sticking card in the battery to hold it there it didn't work that's for trying
