Root lg leon
I have the lg leon lte from metro it hase 5.0.2 lollipop. The kernl is 3.10.49. build numer lrx22g . but i tryed king root and it was no good . aso didnt like that i could not use super su fore some of the apps needed
Try the link I posted and it will work. All you need to do is plug your phone into your computer and run the program then you will be rooted
