PLEASE MAKE THIS STICKY
Download:
1.LG MARQUEE DRIVER
2.LG_Marquee_Root.zip
Unpack, find the run.bat file and double click on it to run it.
1: Download Rom Manager to get CWM >Rom Manager 4.8.1.3<
2: Run App then press on Flash ClockworkMod Recovery, find "LGE Optimus Black" then flash that one.
3:Once its flashed reboot into it using Rom Manager or any other app that allows reboot to recovery such as Anreboot. Once its in the recovery you will get a bunch of error messages that says "Cant mount cache" or something along those lines
3: At this point nothing in the recovery will work so what you have too to is go to mounts and storage and mount /system, then mount /sdcard, then try to mount /data if it doesent work then dont worry about it. it didint work on mine but you dont need to mount /data for it too work it would just help.
5: Now go back to the main menu and wipe Cache Partition once thats done go to mounts and storage and see if /chache is mounted it will say "unmount /chache" if it is mounted
6: If cache is mounted then reboot in to system and then next time you reboot in to recovery the error messages should be gone and you have a fully working recovery.
Now you will always have to wipe cache partition to leave the recovery until AaronEmoBoi fix it.
And when you press reboot it will sit at a blank screen for a while but will show the LG screen after 6 or 7 seconds no big deal
To reboot the easiest way download Quick Boot (Reboot) free off the Android Market. Open the app and select "Reboot into Recovery"
Download:
1.LG MARQUEE DRIVER
