need help.my metro lg motion somehow got set to EV mode and i don't know how to get it back to 4 G mode. Does anyone know how to do this? Thanx
Its just a variation of 3GI see "EV" in my status bar. What exactly is that and does it put strain on my battery or OS?
EV is short for Evdo which is 3G, same LTE is short for Volte/Lite which is 4G. if you know you have a decent 4G signal wherever you might be, just trigger airplane mode or disable data for a few seconds. once it connects from being disabled then you should be connected to the strongest signal in your area
I am totally confused. I am away from home now and have been trying to access webpages. I noticed the icon at the top of the screen changes back and forth 4g to ev. Sometimes it ch
anges to 1x. What is going on? What does all this mean???
It means your in weak coverage area for those networks so your data network type keeps changing.
