A
Android Question
Guest
I decided to use a pattern lock screen on my LG Motion (MetroPCS) and now I can't get the lock screen back to the Slide option.
I also tried to get back from the pin code but I don't want that either.
When I attempt to change the lock screen to None or Slide I get an error message as follows:
Note
No applications can perform this action. Enable disabled built-in application?
When I tap OK it takes me to the Face Unlock app, which I don't want to use.
Does setting this back to None or Slide require a hard reset?
Note
:thumbup:
