LG Motion Questions
Welcome aboard, I am not too familiar with your device, I will direct you to your device forum, I am sure will be able to help you best there, cheers.
LG Motion 4G
Sub-Forums:
Motion 4G - All Things Root
How do I move things (i.e. Apps, Contacts, pic's) from my phone to my SD card? :confused:
Hello and welcome aboard.
Thanks for joining the community - below are two links to two applications that should assist you with your concerns.
Link 1. http://r6re.qr.ai
Link 2. https://play.google.com/store/apps/details?id=com.a0soft.gphone.app2sd
You can also move installed applications to your sd card by going into settings - applications - downloads/downloaded choose the app - move to device sd card.
I hope this helps. :)
Hey there and welcome to Android Forums. :)
To add to what Rush said, your pictures should automatically me on your sd card, and if your device is supported, you should be able to hit the menu button while in your contacts and it should give you a import/export option.
If you have any questions don't hesitate to ask. :)
DS
