Mine does that too occasionally. It usually means that there are too many background programs running. Try installing a task killer and something like fast reboot. Run those regularly and you should see a difference.
I am learning that the more advanced that the Android platforms are becoming the more like desktop PCs they are becoming... Which means that we are soon going to have to use utilities for defragmenting, etc...
Go into your settings menu then and look at how many of your apps are still running even AFTER you think you have exited them... Then come back and tell me whether or not you still need a task killer... Some of the better apps will terminate after you exit them, but some don't... The ones that don't will eventually build up and cause your phone to crash...
Ok, so I just checked out that app. Even the programmer advertises it as a task killer, so what's the difference between this and other task managers?
