Help LG OPTIMUS 3D Stuck in recovery - please help
I have an LG OPTIMUS 3D (LG P920). I have Clockwork mod & Titanium backup installed as I was looking to root it and upgrade the ROM. On the CWM setup I pressed "Reboot into Recovery" and now all I get is:
Android system recovery <3e>
Android system recovery utility
reboot system now
apply sdcard:update.zip
wipe data/factory reset
wipe cache partition
When I select "apply sdcard:update.zip" It gives me:
-- Install from sdcard...
Finding update package...
E:Can't mount /dev/block/mmcblk1
(No such file or directory)
E:Can't mount SDCARD:update.zip
Installation aborted.
I've also tried using:
LGNPST
LG Mobile Support Tool
LG Mobile Software updater agent
LG Flashtool
ADB push
Unfortunately, I haven't had any luck with any of these or I wouldn't be asking for your help.
I've tried to ensure that I have the right Modem and USB drivers installed but still don't see my device with the Flashtool or the LG support tools.
I am able to connect to my device with ADB
I thinks I'm missing something with mounting the SD card or messed up the partitions maybe?
Your suggestions please..
Thanks in advance,
Conrad
