some time while i am on call it will run hardly for 5 min and screen will go off. all four buttons will start blinking if i try to switch it off it will not respond. all i have to do is removing and resetting the battery to restart the mobile... because of this prob i removed my SD card and used the mobile its working fine till now.
is any one is facing the same problem. i cant keep my mobile without SD card. if any other solution please share...
Oh, and before removing the card make sure you always unmount it.
