lg optimus m+ ms695 boot load
hello
any one know how to unlock the boot load
on the lg optimus m+ ms695
i am try to install custom rom on my phone
but every time the phone reboot, is the same lg boot load
something must be lockd on that phone please help
thanks
Well, unless you have made a custom ROM for the OM+, then you shouldn't be trying to flash a ROM from another phone. We don't have any for our phone yet. That's a sure fire easy to brick it; putting a ROM on for another phone.
If I am right, the MS695MZV4 has a very unique dir/storage map:
/mnt/ ftype device [device2]
/boot emmc /dev/block/mmcblk0p9
/cache ext4 /dev/block/mmcblk0p16
/data ext4 /dev/block/mmcblk0p21
/misc emmc /dev/block/mmcblk0p8
/recovery emmc /dev/block/mmcblk0p17
/system ext4 /dev/block/mmcblk0p14
/emmc vfat /dev/block/mmcblk0p20 /dev/block/mmcblk0
/sdcard vfat /dev/block/mmcblk1p1 /dev/block/mmcblk1
/sd-ext ext4 /dev/block/mmcblk1p2
Nothing is even close to this nightmare.
here's the system at boot:
dev/block/vold/179:20 /mnt/sdcard vfat rw,dirsync,nosuid,nodev,noexec,relatime,
uid=1000,gid=1015,fmask=0002,dmask=0002,allow_utime=0020,codepage=cp437,iocharse
t=iso8859-1,shortname=mixed,utf8,errors=remount-ro 0 0
/dev/block/vold/179:20 /mnt/secure/asec vfat rw,dirsync,nosuid,nodev,noexec,rela
time,uid=1000,gid=1015,fmask=0002,dmask=0002,allow_utime=0020,codepage=cp437,ioc
harset=iso8859-1,shortname=mixed,utf8,errors=remount-ro 0 0
Life doesn't have to be this way...
Ok, it is a unique system, that expands on the RAM "swapiness" idea, yeah we get it.
Don't be discouraged, because when the optimus grows up, it wants to be this...
df
Filesystem Size Used Free Blksize
/dev 198M 40K 198M 4096
/mnt/asec 198M 0K 198M 4096
/mnt/obb 198M 0K 198M 4096
/mnt/extasec 198M 0K 198M 4096
/mnt/extobb 198M 0K 198M 4096
/system 826M 284M 578M 4096
/data 500M 152M 348M 4096
/persist 7M 4M 3M 4096
/cache 157M 4M 153M 4096
/drm 7M 4M 3M 4096
/mpt 15M 12M 3M 4096
/data/sdext2 4G 99M 4G 4096
/mnt/sdcard 7G 345M 6G 16384v
This is my MS695ZV4 with a 16Gb SDcard mounted.
We'll for about 30 minutes, then it was: "With this phone, I can do anything....I wonder what's inside this little android?" =two weeks of bootloading and bombing, till I brought my phone back to factory with the KZ-5000 utility.
cumofo
cumofo
oK! The SDcard multimount utility is an apk widget you toss on your desktop. It mounts the SDcards in one click.
SO, playfulgodz...IF ANYBODY knows how to unbrick this phone using KZ 500 Utility ITS YOU....
Would you have time to shoot some instructions on the matter?
Or do you know an easier,or better way to get this done? Ive been around here long enough to know ur 1 of the best. as far as developers go.
Any help you can give me is appreciated bro thanks for ur time..
IRISHMAN
IRISHMAN
I've never used the KZ 500 utility so I cant say on it.
At this time I dont know of any way other than whats been posted.
I can check with a contact about a tot for it, but we still havent had any luck with the needed dlls for the others we got.
Thanks bro, that .ToT would be a huge step in the right direction for me...I got a lot of respect for you bro.. even when your not directly helping me, probably 90 % of the threads that i end up relying on to fix or mod phones end up being threads, mods, or software development, you created on or info youve shared on this site in the past. your knowlege is respected and appreciated.
thanks , Irishman
You can change your boot image with ROM toolbox pro
thats the boot splash (LG logo in this case) it changes and its only for certain devices like the DroidX, not one LG is supported by that feature. And it sure as shyt cant change out the boot.img !!! ;)
