I have an Optimus T P509 with 2.2.2 on it. I'm using gingerbreak v1.2 (which I saw was the one I should use for my 2.2.2) and when i hit "Root". How long does this take? I am now on my first hour and it is still going. I also saw that I needed gui.apk and a gapps file if I wanted to use a different rom. Is this necessary if i am not using a different rom at this point? I would like to get rid of the junk apps to free up space and also might want to use a different rom later when I know more about them.
Does anyone have any insight for me? this is my first time doing this.
Thank you,
Kristoco
UpDate!!
Well I got the phone rooted and started to put the rom on it and when I go to load the zip file for the rom it aborts the load. Anyone have any ideas?
I have tried both: cyanogen_thunderg-ota-eng.mik-6.5.8 and cm-10-20120909-UNOFFICIAL-p509. I am all out of ideas.
Sorry for the repetitive messages yet this is what I get when I try to put one of the zips above: for the cm-10-20120909-UNOFFICIAL-p509, Installing: /sdcard/cm-10-20120825-UNOFFICIAL-p509.zip
Finding update package...
Opening update package...
Installing update...
assert failed: getprop("ro.product.device") == "thunderg" l l get prop("ro.build.product") == "thunderg" l l getprop("ro.product.device") == "p509" l l getprop("ro.build.product") == "p509" E:Error in /sdcard/cm-10-20120825-UNOFFICIAL-p509.zip
(Status 7)
Installation aborted.
Please....anyone?
Thank you,
Kristoco
UpDate!!
(Status 7)
Please....anyone?
