LG Optimus V Bundle
DCBlueStar
Just thought I'd share a find/purchase.
I just bought this from eBay. It's like a "knock off" or "aftermarket" but not of bad quality.
Car Holder + Charger + Case for Virgin Mobile LG Optimus V
Starting Bid: $9.99 - Buy it Now: $14.99
Car Mount Holder allows mounting your cell phone, PDA, MP3 player, GPS navigation unit or pretty much anything in your car, SUV or truck while you're driving. Conveniently mounts to windshield via suction cup or clips on to air conditioner vent. Locking suction cup provides a stable and secure attachment to windshield. Fully adjustable arm locks into any position without drooping or sagging. Your device can be mounted onto the holder either vertically or horizontally which makes this car holder fit practically any device you wish to mount in your car. Soft-release holder releases your device at the push of a button slowly, which prevents you from dropping your device. Suitable for cell phones, PDAs, PDA phones, MP3 players and GPS navigation units 1 10/16 to 3 11/16 inches (42 to 93mm) wide/tall.
  • Highest quality generic Car charger for your Cell Phone
  • Durable coil cord for extendable reach and use.
  • Provides power to your phone while simultaneously charging your phone's battery.
  • Small and lightweight for convenience, portability and storage.
  • Original battery will be charged to 95% capacity within two to three hours.
  • Talk while you are charging your phone at the same time.
  • I/C Chip technology prevents your phone and battery against overcharging
  • LED indicator lights up when charger is ready and powered.
  • Dual Magnets for superior close
  • Bold & Impressive stitching
  • Soft Felt interior
  • Strong Durable fixed belt clip
  • Perfect fit: precisely engineered to fit your phone perfectly
  • Impeccable Workmanship
  • Stay close to your body allowing you to feel the vibrate mode clearly
  • This is a brand new fitted leather pouch for your Phone/PDA
  • The inside out the pouch is lined with a velvety felt like cloth to protect your device from scratches
  • Perfectly custom fit for your Phone/PDA
  • Strong fixed durable belt clip on the back
  • Sharp, bold & impressive stitching
>--------------REVIEW--------------<​
Mount has a nice suction, AND we needed a new mount for our GPS (which I don't need anymore cause I have my Optimus V :D) and it works perfectly. In fact I can adjust it to hold just about anything *cough* my old iPod *cough*
Only con is it doesn't swivel... at least I don't think so but I haven't tried. Has great suction. Has two or three areas that you can adjust to get it to the right angle. You can either put it on the windshield, the dash or use the vent clip.
Nice sturdy belt clip case (fits my phone even with my thick carbon fiber case), and the car charger is great.
Can't beat the price, either.
Let em know DCBlueStar sent ya :P
