bradbesoballa
My optimus has been out of commission and i finally decided to bring it back from the dead.
However, It has a few problems.
1: PHone can't boot into recovery, nor bootloader.
2: Phone will boot normally to the lockscreen but cant unlock without freezin/restarting.
3:Wont boot into safemode without going into a bootloop. But a battery pull fixes that.
4: Phone wont show up in windows. I think that USB debugging is on, but i can't tell because the notification bar does not show up on the lockscreen.
5: If the phone is on for too long, it wont turn off but the screen looks like colorful static and is unresponsive.
6: ADB isnt recognised in a command prompt window.
Im not sure if ODIN can pick it up, but im not quite familiar with it. Ive never really had to use it.
I did ABSOLUTELY NOTHING to the phone. The battery died while i was in the car one day, and its been like this ever since.
So, as you can see, there are a few problems. If anyone knows anything about this, or has experience this and fixed it, PLEASE, help.
Thanks in advance!
Thanks in advance!
