Lg optimus vm760 ROM
slgdad
I just got this phone it is a old lg optimus vm760 i have root and custom recovery.. But I can NOT find any roms to flash for this phone and what Roms I have found all have bad links and can't download.. Any help would be greatly appreciated....
Downloaded fine for me just now...
Did you verify the MD5 for the downloaded file? Always validate downloaded file's integrity before any flashing.
Which recovery and version are you using to flash? Make sure to use a compatible recovery.
I am using recovery Xionia CWMA v1.2518.6.. It keeps saying bad signature.. Or something.. I'm thinking it might be my recovery..
Leave the Xionia recovery.zip on the root of your sd card in case you need to get out of a bootloop.
Now download the CWMT Recovery from here
CWMTRecovery_5.0.2.7-th7_thunderc
This will be in .zip form, put it on the root of your sd card (not in any folders) ,flash it like you would a rom, no need to wipe or format anything, now reboot recovery, you will now be in your new 5.0.2.7 touch recovery.
Now wipe data /factory reset, wipe cache partition, under advanced sub-menu, wipe dalvik-cache. Then under mounts and storage sub-menu, format all partitions except sd card.
Now install MiRaGe.zip and gapps.zip from sd card, reboot system, enjoy!
