Help Lg optimus
if you havent rooted your phone and deleted anything important,go to your home screen.hit the settings button on the bottom left of your phone.hit settings,wireless and networks.check the box that says WI-FI.now it should be turned on..now right below that check box it says wi-fi settings,go into there and now you should see your open networks..select the one you want to connect to and you should be straight.
