Help Lg Revolution stuck in recovery
My Revo is stuck in recovery!!!! help please
Hello kidmoon. Welcome to Android Forums. :)
Can you navigate the recovery menu with the volume keys? If so, select the "boot now" (or restart, not sure of the wording on that device's menu). If no response or no boot up, try the factory data reset option.
If you cannot navigate the menu:
Is the device rooted? If not, first try holding down the power button for at least 30 seconds steady.
If no change, remove the battery, wait a minute, then put it back in and try a boot up.
it is rooted. ive done everything to try and get it to boot. I installed the exitrecovery.zip and it boots all the way to the Verizon 4g screen and then goes black. tried to recover and it says error /system and error/data
