Root LG Spirit 4G Official Firmware MS87010a
thanks
Non of the links work
LG: Stops at 22%
DropBox: File Removed
Torrent: No Seeders
Is there another way to download the file.
They all point to the same link as in this topic.
Also when I searched the net it seems to be the same on most sites :/
I am uploading the kdz that i have on my laptop right now. Might take a bit my internet sucks. Not really sure if im breaking any rules or not. Got the file from the site i suggested earlier when the link worked.
The only one im missing is the lg spirit official firmware, I cant seem to find it without being redirected to this forum! Any help would b great thanks
This is Links For the Firmware for the LG SPIRIT 4G 870
* Here is a link for the Firmware .KDZ
http://www.mediafire.com/download/lvozzfwl8vd6x3p/MS87010a_05.S10a_05.P3032.kdz
Installation of .KDZ READ;
unbricking and restoring LG Spirit 4G From .KDZ file;
1: Download Stuff and Setup
* Download Firmware *.KDZ File Here: - MS87010a_05.S10a_05.P3032]MS87010a_05.S10a_05.P3032
* Download Tools and drivers: - http://androidforums.com/spirit-4g-...-return-stock-lg-spirit-4g-5.html#post5484651
Note: PUT ALL NEEDED SOFTWARE IN A DIRECTORY IN YOUR ROOT DIRECTORY NAMED "C:\phone"
I DO THIS FOR ROOTING AND INSTALLING CWM-T RECOVERY AND 2ND INIT RECOVERY.
* Disable antivirus software
* Install phone drivers
* Install msxml.msi
2: Prep Phone
* Get into Emergency Mode (Download Mode) From powered off, Hold volume up and down and plug cable into USB.
NOTE: (To get out of e-mode, hold power button for 10 seconds, or pull battery.)
(( DO NOT DO THIS WHILE FLASHING ))
3: Installing New Firmware
* Open KDZ_FW_UPD.exe
* in "Type": choose CDMA
* in "Phonemode": choose Emergency
* Click the folder icon and choose the .KDZ file you down loaded that you copied to your "c:\Phone" Directory.
* Click Launch software update .
* Let software complete the install to phone. It will reboot, But will need to complete installation.
* just let it complete. when done exit software, unhook and reboot you phone.
* set up you gmail accounts and then enjoy!
* Here is a link for a LG Spirit CWM Installable .zip File.
http://www.mediafire.com/download/3sgj36az8z5r3jg/Spirit_Odexed_Stock_Bloated_Rooted.zip
i want to thank everyone, for all their help. a very big thank u to viperdink for giving me all the other downloads, in the hope of getting my phone back! i will be trying to fix it tonight! keeping my fingers crossed!!
My phone rebooted, and it's saying on the phone screen to pick my language..is it done updating the software? Hoping I get a quick answer, kinda worried
;) Don't forget to thank Sammyz,Drbliss,Playfulgod,horak13 and all the Developers here at Phandroid, Without their help and this Community as a whole, None of this would be possible. ;)
To everyone that took the time to post all the downloads and instructions, for those of us, that unfortunately bricked their phones..I want to thank you!! I was able to get my phone back! Really didn't think I could do it, but without this forum site, I probably would of just thrown this phone with the rest of them, in the cellphone junkyard! Keep up the great work, and very grateful! Thanks!!
