lg spirit sd card disconnecting
Vulpine82
i have been noticing that my lg spirit sd card disconnecting and reconnecting symbol comes on and it will give a warning not to disconnect the sd card with out mounting but the sd card is internal and not accessible with out taking of the case
is this happening to any one else ?. is there a fix or an update on the way to fix this ?
Either your SD card is going bad or its not seated properly in the SD holder. Or a pin is kinda bent making an unstable connection. My thoughts.
i put another sd card in and it is still doing it as far as the pin being bent im looking in the best i can but don't see any difference in appearance from pin to pin
