Help LG Thrill (Optimus 3D) Telus 4G Issues
jrymcmb
Not sure if there are any Canadian users on here, but I have an LG Optimus 3D (Rogers) unlocked, using Telus (V2 SIM card) I have no problems loading up apps, or using them to their full extent on WiFi, however, when I am on 4G I cannot log in to my TD App, I can't view pictures on Facebook, or even run a speedtest, another note when I attempt to run a speedtest it tells me there is no network present.
Browser works no problem, I can go to any website and view anything, its just problematic when I'm trying to use data on my Apps, has anyone heard of this problem ? It seems that it has only started happening when I upgraded the OS to Gingerbread. Telus has no idea why this would be happening, and all LG tells me to do is a factory reset, which I've done twice.
Any possible solutions ?
Thanks !
Hello jrymcmb,
I noticed that you too was/still experiencing issues with LG Unlocked on Telus and the app not connecting to 4G – only on wifi. I, too am experiencing that same issue (Telus aswell with an unlocked LG phone).
Have you had the chance to get this resolved? From changing apn to sp.telus to isp.telus it’s pretty annoying to get this to work that way it should be.
Let me know if you’re able to find a solution – I’m running out of keywords to google when trying to find a solution.
-angelitojr
