Help LG Thrill screen broken - white horizontal lines
jroul
Hi all. I've been googling around for some kind of help, but have so far been unable to find any responses.
My (relatively) new Android LG Thrill (from AT&T) has suddenly acquired a set of thin white lines running horizontally, evenly spaced about 3-5mm apart from the top to the bottom of the screen, along with some minor flickering, and what looks like icons smearing vertically.
When put in 3D mode, the screen appears to work perfectly from a certain angle, then distorted in the same manner from a second angle.
The touch functionality seems to work perfectly....
If anyone has some tips or ideas, I would much appreciate it. Any other information can be provided as well if needed.
