D
Deleted User
Guest
WARNING: DO NOT FLASH ANYTHING TO BOOT OR RECOVERY. IT WILL NOT WORK. BUMP WILL NOT WORK. NO EXPLOIT IS AVAILABLE RIGHT NOW. TEMP ROOT IS THE BEST THING YOU HAVE.
Hello, everyone. Let this serve as a guide for the LS665 (boost mobile). This is about the only info out there as the device is a month old. I have put all of the findings I have gone through below. Smack the thanks button around if you find it helpful.
Device Codename: LS665
Android Version: 5.1.1
Kernel Version: 3.10.49 (Source)
Baseband Version: MPSS.DPM.2.0.c11-00021-M8936FAAAANUZM-1
Build number: LMY47V
Software Version: LS665ZV3
Root is available on LS665ZV3
Root: King Root
Vulnerable To:
Partition dump backup:
DOWNLOAD IT HERE (System rooted, but can uninstall)
Getting into "Download Mode"
Getting into Recovery Mode
Boot / Kernel info
fstab
Battery Cover Pin Out
Did you know you dont need the battery cover on to manipulate power on, off, volume buttons.
Here is the pin out:
bottom right - common ground
bottom left - Volume -
top right - Power
top left - Volume +
To turn on power, youd get a paper clip and connect the bottom right with the top right. If you want power and volume down (recovery) youd connect the bottom left, bottom right, and top right pads together.
Root: King Root
Vulnerable To:
- CVE-2015-3828 (start stagefright)
- CVE-2015-1539
- CVE-2015-3824
- CVE-2015-3829
- CVE-2015-3827
- CVE-2015-1538 (end stagefright)
- CVE-2015-3636 (ping pong)
Partitions
Code:
lrwxrwxrwx root root 1970-01-01 00:20 DDR -> /dev/block/mmcblk0p23
lrwxrwxrwx root root 1970-01-01 00:20 aboot -> /dev/block/mmcblk0p5
lrwxrwxrwx root root 1970-01-01 00:20 abootbak -> /dev/block/mmcblk0p11
lrwxrwxrwx root root 1970-01-01 00:20 boot -> /dev/block/mmcblk0p18
lrwxrwxrwx root root 1970-01-01 00:20 cache -> /dev/block/mmcblk0p37
lrwxrwxrwx root root 1970-01-01 00:20 carrier -> /dev/block/mmcblk0p35
lrwxrwxrwx root root 1970-01-01 00:20 drm -> /dev/block/mmcblk0p31
lrwxrwxrwx root root 1970-01-01 00:20 eksst -> /dev/block/mmcblk0p26
lrwxrwxrwx root root 1970-01-01 00:20 encrypt -> /dev/block/mmcblk0p25
lrwxrwxrwx root root 1970-01-01 00:20 factory -> /dev/block/mmcblk0p29
lrwxrwxrwx root root 1970-01-01 00:20 fota -> /dev/block/mmcblk0p30
lrwxrwxrwx root root 1970-01-01 00:20 fsc -> /dev/block/mmcblk0p21
lrwxrwxrwx root root 1970-01-01 00:20 fsg -> /dev/block/mmcblk0p20
lrwxrwxrwx root root 1970-01-01 00:20 grow -> /dev/block/mmcblk0p39
lrwxrwxrwx root root 1970-01-01 00:20 hyp -> /dev/block/mmcblk0p3
lrwxrwxrwx root root 1970-01-01 00:20 hypbak -> /dev/block/mmcblk0p9
lrwxrwxrwx root root 1970-01-01 00:20 laf -> /dev/block/mmcblk0p17
lrwxrwxrwx root root 1970-01-01 00:20 metadata -> /dev/block/mmcblk0p14
lrwxrwxrwx root root 1970-01-01 00:20 misc -> /dev/block/mmcblk0p12
lrwxrwxrwx root root 1970-01-01 00:20 modem -> /dev/block/mmcblk0p33
lrwxrwxrwx root root 1970-01-01 00:20 modemst1 -> /dev/block/mmcblk0p15
lrwxrwxrwx root root 1970-01-01 00:20 modemst2 -> /dev/block/mmcblk0p16
lrwxrwxrwx root root 1970-01-01 00:20 mpt -> /dev/block/mmcblk0p32
lrwxrwxrwx root root 1970-01-01 00:20 pad -> /dev/block/mmcblk0p6
lrwxrwxrwx root root 1970-01-01 00:20 persist -> /dev/block/mmcblk0p13
lrwxrwxrwx root root 1970-01-01 00:20 persistent -> /dev/block/mmcblk0p34
lrwxrwxrwx root root 1970-01-01 00:20 rct -> /dev/block/mmcblk0p27
lrwxrwxrwx root root 1970-01-01 00:20 recovery -> /dev/block/mmcblk0p19
lrwxrwxrwx root root 1970-01-01 00:20 rpm -> /dev/block/mmcblk0p4
lrwxrwxrwx root root 1970-01-01 00:20 rpmbak -> /dev/block/mmcblk0p10
lrwxrwxrwx root root 1970-01-01 00:20 sbl1 -> /dev/block/mmcblk0p1
lrwxrwxrwx root root 1970-01-01 00:20 sbl1bak -> /dev/block/mmcblk0p7
lrwxrwxrwx root root 1970-01-01 00:20 sec -> /dev/block/mmcblk0p24
lrwxrwxrwx root root 1970-01-01 00:20 sns -> /dev/block/mmcblk0p28
lrwxrwxrwx root root 1970-01-01 00:20 ssd -> /dev/block/mmcblk0p22
lrwxrwxrwx root root 1970-01-01 00:20 system -> /dev/block/mmcblk0p36
lrwxrwxrwx root root 1970-01-01 00:20 tz -> /dev/block/mmcblk0p2
lrwxrwxrwx root root 1970-01-01 00:20 tzbak -> /dev/block/mmcblk0p8
lrwxrwxrwx root root 1970-01-01 00:20 userdata -> /dev/block/mmcblk0p38
- Power off
- plug usb in
- hold power and volume up at the same time
- Power off
- plug usb in
- hold power and volume down at the same time
Boot / Kernel info
Code:
page size : 2048
kernel size : 7997632
ramdisk size : 2375543
dtb size : 182272
base : 0x80000000
kernel offset : 0x00008000
ramdisk offset : 0x02000000
tags offset : 0x00000100
dtb img : dt.img
cmd line : console=ttyHSL0,115200,n8 androidboot.console=ttyHSL0 androidboot.hardware=c50 user_debug=31 msm_rtb.filter=0x3F ehci-hcd.park=3 androidboot.bootdevice=7824900.sdhci lpm_levels.sleep_disabled=1 vmalloc=504m
fstab
Code:
# Android fstab file.
# The filesystem that contains the filesystem checker binary (typically /system) cannot
# specify MF_CHECK, and must come before any filesystems that do specify MF_CHECK
#TODO: Add 'check' as fs_mgr_flags with data partition.
# Currently we dont have e2fsck compiled. So fs check would failed.
#<src> <mnt_point> <type> <mnt_flags and options> <fs_mgr_flags>
/devices/soc.0/7864900.sdhci/mmc_host /storage/external_SD vfat nosuid,nodev wait,voldmanaged=external_SD:auto
/dev/block/bootdevice/by-name/system /system ext4 ro,barrier=1,discard wait,check
/dev/block/bootdevice/by-name/userdata /data ext4 nosuid,nodev,barrier=1,noauto_da_alloc,discard wait,check,encryptable=/dev/block/bootdevice/by-name/encrypt
/dev/block/bootdevice/by-name/persist /persist ext4 nosuid,nodev,barrier=1 wait,check
/dev/block/bootdevice/by-name/cache /cache ext4 nosuid,nodev,barrier=1 wait,check
/dev/block/bootdevice/by-name/drm /persist-lg ext4 nosuid,nodev,barrier=1,noatime,noauto_da_alloc,errors=continue wait,check
/dev/block/bootdevice/by-name/sns /sns ext4 nosuid,nodev,barrier=1,noatime,noauto_da_alloc,errors=continue wait,check
/dev/block/bootdevice/by-name/boot /boot emmc defaults defaults
/dev/block/bootdevice/by-name/recovery /recovery emmc defaults defaults
/dev/block/bootdevice/by-name/misc /misc emmc defaults defaults
top right - Power
top left - Volume +
