Help LG Updater crashing
Hey guys.
I have an LG Optimus (for my sins) and recently tried to update it using the PC software package that came with the phone when I got it.
It says update available and downloads it to the PC, then when it goes on to the install part, it gets as far as 4% and stops. I think what's happening is that once the update starts, the phone goes to a Blue Screen Emergency Mode, and once that happens, Windows loses the connection with the device, so the install stops, after a while the phone resets itself, Windows recognises it again, the update tries to restart but the above just repeats its self.
Anyone got any suggestions on what I can do?
Thanks
GR
I had the same problem with my wifes lg shine plus. Lg told me to go to settings/sdcard and phone storage and uncheck the mass storage only box and then it worked fine. I don't know if the same applies to your phone or not.
Hello, i had the same problem and my phone does not restart again.
I need help if anyone can help me, please.
Thank you.
