lg viper battery compatible with lg connect?
wilsonbx198st
i wish to know if anyone know if the lg viper battery fits in the lg connect, the lg viper battery is a 1750 mah better than the lg connect battery
please look into this more, the htc merge/vision/g2/desirez/evoshift were all teh same phone yet most had different batteries.....
meanwhile the htc hero cdma had the same battery as the touchpro 2 and teh htc evo 4g
Well.. thanks for pointing that out. I know you can buy cases now that are specifically for only the Connect and Viper (not the Lucid) due to how much they are the same. You'd think they would save themselves a little cost on mass production and keep them as alike as possible. I guess looks and specs are deceiving. How annoying..
has anyone actually tried getting on. i would go if i knew were a store was. is it fact that the battery fits
I was checking that yesterday. Why the sprint phone has a better battery life when its identical phone.....
The battery life is maybe 50 % better than connect and it has a 1700
how would i get my hands on one of those batterys i believe that those maybe a lot better then stock and its made by lg so it may be better then 3rd party ones
+1 this does anyone know
LG Viper and LG Connect batteries are compatible. LG Lucid battery is neither compatible with LG Connect nor LG Viper. I have deducted it based on the difference in the way LG Lucid looks. In addition, one user on Sprint forum tried it, and, unfortunately, my suspicions were confirmed. I wanted to get an extended LG Lucid battery for my mom's LG Connect so badly.
the batteries are compatible just the back door cover from lg lucid
is not compatible. i'am using the lg Lucid standard battery which is 1700 Mah and with my root it gives me 10 to 12 hours a day. if u get the lucid extended battery u have to get the back door cover separate.
How much do you use it to get 12 hours a day. I am not sure that 1700 mAh is worth the expense; it is almost like a standard battery.
i bought nime online at verizon. it was on sale for 20 dollars. this what i get. for me is worth what i paid
