Root LG Volt 2
Hey guys recently bought the LG Volt 2, I tried to root and ended up in a boot loop as this phone just came out I want to post on here because I need to get the stock rom to fix it so after a few weeks if anyone finds a stock rom could you let me know. I love this phone best one ive had on boost and cant even use it. So if anyone can eventually help out just reply to this thread, thanks in advance!
Or if anyone finds a way to fix it via download mode with ADB or stock recovery mode that would help also. I already tried to reset and wipe cache in factory recovery mode which didn't help
Notice anything wrong in this picture and does anyone else experience this
Looks normal if you're using Link2SD or FolderMount. Use Link2SD's 'Storage Info' or something like 'DiskUsage' to view your storage usage. The stock Android memory page doesn't take symbolic links into account.
Just got a Samsung Galaxy S4 from Boost, $180, screw LG, I'm sticking with what I know works from the past. lol
... later.
Hi guys. whether you can use this phone on a different network? I got root and learned SPC code. I ordered another prl- file. the phone does not see the network. maybe it only works on ruim card?;)
Boost mobile only works when there is a boost mobile sim in the sim slot.
On a side note I found some stock source codes. Not sure if this will help create a custom recovery but if you'd like me to post it just quote this and let me know.
