fido14dido
I posted this here since this seems this issue is directly related to this phone and this forum is the most active with this phone's development. Please move this to the proper forum, if appropriate.
I have two (rooted - stock ZV6 ROM KitKat 4.4.2) versions of this phone (Virgin/Boost Mobile) and both experience the issue with the character refusing to move after a period of time. It happens when I move/drive and stop at a location. When I start to move again, the character does not move anymore and the only way to resolve it is to restart the program simply by pushing the home button and relaunching. (why the program just quits instead of pausing when I press the home button is another issue with this phone/program but is probably very related). Other observations:
Issue has occurred with old and most recent versions of the app from the Play Store
No messages of No GPS Connection or No Connectivity pops up.
Attempted High Accuracy / GPS Only / WIFI Only options. Same results
Google Maps and Waze do not experience these issues
Cleared out all background apps prior to launching
Seems to be less of an issue when I am in constant motion (ie, walking). Always an issue when driving (stop signs/red lights).
Tried a few GPS status apps with no credible evidence of improvement
Installed a fresh debloated stock ROM to resolve issue but problem still persists
Phone runs extremely hot but not very different than my iPhone 5S (which does not have this stopping issue)
Used a program called Kernel Tuner and adjusted the memory settings (in OOM menu) and noticed some improvements with prolonged GPS connectivity. However, the game virtually grinds to a halt and becomes too annoying to even try to play.
Data provider is a Sprint MVNO carrier.
I am not sure if the character stops moving on WIFI only since my router's range does not stretch for very long distances. However, it does seem to move even after I leave my phone down for a long while.
Even though the character does not move on the map, it continues to rotate correctly when I rotate my phone.
I suspect the issue relates to RAM management, or lack thereof, but not technical to pursue much further so if someone has found a solution, please share. Thanks.
