LG Volt TV Connection
I have seen this topic discussed before but I have been looking into hooking up the Volt to my TV. I know MHL is not an option as the phone doesn't support it but it does have mirror cast. Does anyone have any experience with it? Is there any lag there between the phone and the TV itself? Thanks for any feedback provided!
I don't have a Miracast compatible device, but I have Chromecast. Works great for streaming media, but there is a little bit of lag when mirroring the screen. Of course, it warns that it's not optimized for the Volt, and I haven't looked into any tweaking options yet.
How much of a lag do you think? Maybe half a second? If so that actually wouldn't be to bad for my needs.
I wouldn't try to play games looking at the TV. Probably around a second, at least half a second. What are you trying to do?
Well allcast will not work as I do not have a smart TV. I have the PlayStation remote app working on this phone and was trying to see if there were any options to get it to display on the tv but it looks like anything wirelessly is going to cause to much of a delay.
Allcast will work with things like roku3(which I use for streaming movies) and I think xbox and playstation
miracast works with a fire tv stick, there's the expected lag but i'd say it's more stable then chromecast (which likes to randomly kill the connection)
I've never had that problem outside of YouTube, and I believe that's an issue with YouTube, not Chromecast. It also only happens when the screen goes off on the phone.
your phone is very special though ;) :p
it does say it's not optimized for the device, so i don't expect it to work 100%
