Help LG Widgets
telemike
Anyone found a way to get the widgets from the Optimus T for the S version? I liek the LG widget for clock/weather (sense like) that the T version has.
I guess the marketplace has some Sense like clock/weather widgets that the S could use?
Cool thanks! I have Sense Glass Clock Widget but it has force closed a couple times. Might give that one a try. :)
I could not find the "box" time widget on the fashion id.....does anyone know which id it is in, or which app I can download to get it? (The Eiffel tower wallpaper is part of the fashion id, but I did not find the clock....)
It looks like a similar clock widget is part of the "Beautiful Widgets" paid download, but there were a few negative comments on this app, even if it is at the top of the list. Has anyone tried this app?
You would think that a clock that is on the phone box and many print ads would be on the phone!
If your taking about the black clock with yellow numbers.its in the sprint id pack. I actually like the widgets that sprint has so I copied them from data/app to my sd, removed the sprint id and installed the ones I like from the sd.
Im using the Redrum clock and it looks awesome IMO.
I was actually wondering where to find the box clock as well, im gonna try searching for Factory Widgets :)
