Root LGNPST won't work on my PC
Lawkev
Member
Hi,
I have tried to follow the instructions found here for downgrading from 2.2.2. I am getting stuck because LGNPST won't work. I am running Windows 7. When I click the short cut on the desk to I get an error message so I click the icon from the C drive. It starts then I get a message saying it is not working and it shuts down. Gingerbreak is not working. Also in Joneidy's post he mentiones: "**Then drag the MS690.dll file on top of the Reggie.exe file to register the MS690.dll file.** <---- Very Important step, Make sure to have Administrator Rights." When I do the I hear a "bung" sound and I get a message. I don't know if that is normal.
Thank You
Hi,
Thank You
I dont know if you fixed it but if you have not an would like some help look up team viewer and download and install it and pm me a time that will work and we can go from there.
it should not be too much trouble usually its one of 3 things, first being if you did not reboot between installing all components it does not work.
