Root Liberty Gb 591 help
OKAY!!!! so i just did some downloads through Liberty toolbox today but i cant seem to figure out whats different and how to get a theme on it like i used to be able to..
i will give a full walk through of everything i did. see if you can tell me if i did something wrong at all..
okay so i was on L.GB .588 and went into LTB and looked under nightlies and saw 3 new things...
L GB v0.5 (if your not on 591 then install this, and come back and install Kernal update)
L GB v0.5 this is the newest leak. YOU MUST ALREADY BE ON GB this zip includes the kernal. so use if you are on any previous GB leak
591 Kernal Update
so, since i wasn't to sure what this really meant because i was on GB but it was the Liberty GB v0.4 so i did the first one, with a full wipe and came back and downloaded the kernal 591.. after that i decided just to be safe and downloaded the 2nd one that was for if you were on GB already, did a full wipe on that as well.. when it all started up everything looked normal nothing was really any different checked the about to see if my phone showed i was on .591 and 2.3.3, it said i am.. so alls good right?? well whats the big difference?? and where can i get a theme .zip to use?? maybe one that will look like the xoom?? cause from what i have read is the 2.3.3 software is the phone version of 3.0 right?? haha sorry i feel like i am being a snob, and i don't mean to be! i think all the dev that make this rooting work so well are awesome and wish i could do my fare share in helping.. i just don't know where to start so i let them do the work and ill show all my friends how awesome it is! :) forming here is amazing you'll seem to have helpful stuff that makes me grow in my root knowledge ;)
