Root Liberty Gb question
scottymedic
I got a question on whether i should keep using liberty gb im on version .5 or should i try another gb rom and which one might better suit my tastes
P.S. steven if i posted the wrong section my bad havent posted anything on phandroid app before :)
lol it is in the wrong section but thats ok, a guide will move it soon.
now if you purchase the liberty donate app ($5) then you can flash the new Liberty GB rom from any froyo based rom! i do not know how they have managed it at team liberty, but they did. otherwise you need to be stock froyo, and maderstcok will not work, you have to SBF to move to GB
for more info respond and i will be glad to assist you
You the newer updates to it require gb i flashed the version .5 from .595
Edit this one wasnt supposed to post lol
wait im lost at what your askin, are you already on liberty gb? if you are i dont think there is anything higher than .5 at the moment, there are a few themes out there, but i do not believe a .6 or .7 is out yet
Sorry for the confusion im on liberty gb .5 but i know theres alot of other roms for gb just trying to find out if any of them would be better than liberty ive been a big fan of liberty was on liberty on froyo until gb came out
Not to happy with the keyboard lol keeps putting in the wrong words
there is Apex gb 2.0 and broodcomb not a whole lot, just yet, cause the devs are waiting for the official ota
you may be able to flash the apex gb rom over the liberty gb rom, i dont see a problem in doing it, just make sure you wipe data and cache first bud :)
Ive tried broodcomb i think it was version 2.0 its on my sd card still havent tried apex ive also tried i think it was gingeraid i think 4. something wasnt ti happy with them ive got the deodexed .595 leak saved as a backup so if i need to i can roll my phone back to it ive been thinking of trying zombiestomp
Just checked my sd card it was broodcomb3 for 595
i was very happy on apex 2.0 but i am going to go to .595 rooted deodexed and just wait, until the official ota and more themes to be released
Sorry took so long to reply at work on my ambulance i liked the rooted and deodexed .595 its just i cant stand bloat drives me bonkers and it sucks up my battery even on 595 and im not experienced with modding my phone just recently learned how to root and flash roms other than the bloat i love 595 kinda sucks liberty gb .5 is running of the .591 leak
Battery life is a big seller for me on roms this liberty rom's battery aint that great but its better than what was getting on stock froyo now my liberty on froyo had very good battery life
