Root Liberty gb?
keegan1014
I'm still on froyo, and would like to know if I use the liberty tool box can I get on gb by using the froyo to liberty gb? And will I still have root and what else would I have to do. If I'm reading it right seems as thou all I need to do is download the rom do a wipe and I'm good to go.
yes you can
only with the liberty toolbox donated, it includes the liberty gb coming from froyo, you got to find the right one though, and yes just a wipe and your good to go
Opps please help had a failure at install it didn't prompt me to wipe, and wernt threw with the installation. Phone is stuck at boot logo. Can access cwrm but try to install liberty gb and I get a assert failed error sd card status 7 install aborted, now I'm stuck
