I have tried finding a clear answer on this, can anyone help? I am wondering what the process is to go from newest liberty ginger build to the OTA friendly .595?? I like Liberty, and am glad I donated, but after using it for a few days, I will probably wait for a later release.
since its both gb i would suggest
make a backup of your current liberty build
then enter droid 2 bootstrapper
wipe data and cache
and install the new gb leak
they are both GB so it should install just fine. and if not sbf is easy ^_^
Good to hear. I'm contemplating flashing from Apex 2 Beta to .595 but was awaiting another user to confirm this worked out ok. I'm presuming since you had success going from liberty then I 'might' also...
I wiped data a couple times and the cache a couple times also. Probably not necessary, but I am paranoid. I'm still setting things up, but even while syncing facebook, contacts, and downloading apps this thing seems to be zipping around quite nicely. I usually do one at a time, but I wanted to see what the new build could handle. Pretty impressed, thus far.
