Light Flow App
lamoglinsgal
Android Expert
Anyone else use this? It actually will change the LED notification from green to orange to dark orange. I just installed it and need to play with it some, but so far, I cannot get the notification to actually blink. It stays steady, even with the option to blink on. :confused:
As far as I can tell, the LED on the TB isn't very versatile. I wouldn't be surprised to find that apps such as these have little use for us. :( I guess we'll have to settle for all of the other amazing things this phone is capable of. :D
Hi, yes I've not supported flashing yet on the thunderbolt (or any htc newish phones)
Every method I've tried so far uses too much battery for my liking.
I do hope to eventually add it, and maybe even try disco lights - where it'll flash a sequence of colors quickly in succession.
The thunderbolt is limited in it's led hardware (as all new htc phones are) pretty much to just a green and an amber led.
Good luck, if the Tbolt is like the Inc, your not going to be able to change the color of the LED. The community has tried it but all we have is green and orange.
I very much miss the X's ability to change LED colors for every Notification. Oh well. Speed is worth it.
