Light Flow on BSGS2
dhabell
Im on stock Boost rooted FG31.
couldnt get Light Flow working right.
we only have red and blue right?
well I tried to set up notifications for Handsent, Yahoo, Line, missed calls and voicemail. none of them worked.
does someone know how to do it?
Is it the light flow app on Google's market you are trying to use? I f so I am taking a look at it now to see if it will work for me.
Codegerm
yes i believe its in the market.
i could only get it to do red and blue though. which is what it does anyway..
and you can only adjust the light to stay constant on, very slow strobe or custom frequency. (the custom frequency is really picky and you cant make it go faster, you can only make it stay on longer and blink slower.)
I couldnt get the priority thing to work right either. (I wanted it to strobe blue if I got a text while charging...)
I finally set it up to blink red very slow when battery is critically low.
stay constant blue when a text is received while not charging.
and to turn constant red while charging
I set it up to turn constant blue once it was charged to 99% capacity but that is not working either.
If someone can find some custom E4GT or SGS2 Light Flow settings that would be great!
It seems to be a bit fussy. If I get it to work right, I will definitely let you know wha settings I used.
Codegerm
