Help Light surrounds the touch buttons
Demacia
1LU2g
anyone else having this problem?
light forms like a circle around the buttons
Problem it's not. That's normal.
You can go into settings and change the duration of how long it stays lit if that bothers you.
That's normal, my white note does same. It's just light bleeding through plastic, nothing you can do about it other then get blue version so light doesn't show through dark plastic
Yeah, the Grey one doesn't do that. Very crisp back arrow or menu button only light up. No light "bleed" through at all.
Yeah white one bleeds and grey one doesn't. I, too, actually like the light bleeding, but I have the grey one.
Its really not that bad but if your that picky about it, return and or exchange it for Titanium Blue I guess
I wouldn't normally chip in here as I may be in danger of voicing my opinion of white phones (let alone non existent Titanium Blue ones ;-) but I have a solution.
You could get very, very good at painting miniatures (should only take a few years and possibly some gene therapy to aid coordination and muscle control), find a white lacquer that exactly matches the finish of the phone and paint around the buttons.
My white one does it too, does cheapen the look somewhat.
Really?
IMO, I disagree.
Also, I've changed the duration of the light illumination so if it weren't for this thread I wouldn't have noticed it at all.
Some "issues" are non issues to me.
That tiny bit of light bleed is not worth me returning my phone.
Really?
IMO, I disagree.
Apart from the fact that it That colour reserved for cookers and fridges. Sorry, Sorry. I wasn't going to go there.
Honestly, I think it looks cool, its like a "halo" effect. But hey, if your that picky, get a Titanium blue version or get some white out if your that desperate.
I'm so glad I despise white as a phone colour. Still have to see this titanium blue one though. Have only seen grey in the titanium. The S3 had pebble blue of course. Perhaps therein lies the confusion.
