Help lines on screen
rwolf
I'm really hoping someone can help me. Last week some lines showed up on my screen. They look like they are left over from when I unlock my phone. Thin black lines. And they move around. They are never in the same place or configuration. If they were always the same I would think my lcd is cracked. Anyone have any ideas?
Do you have a case on your phone, extended battery with standard door, anything like that?
Certain accessories not properly molded or installed can cause 'warping' and put pressure on your phone. If you have anything on it, try taking it off and see if that cures it.
In my case, when I tried to get away with the extended battery while using the standard size door, they were iridescent circles, so I can at least confirm that having things fit improperly can cause screen issues
MY PARTNERS PHONE WAS DOING SOMETHING LIKE THAT BUT THEY WERE TRACERS AFTER HE D TOUCH THE SCREEN i had gone into his settings and there was some setting that was a pointer locater of some kind i m pretty sure that it was called that . i disabled it and he was on the road with a clear screen again
