blazen-moto
Member
I've been fooling around with with the terminal emulator on my phone and decided to post a list of the most common commands and those of which I used.
Obviously, you need a terminal on your rooted devour to run these commands
(I personally would recommend "Android Terminal Emulator" by Jack Palevich)
If you didn't know that before I told you, then you really shouldn't use these anyway.
These commands have the potential to brick your phone if used incorrectly, but at the least they can also delete important files that could make the phone useless. Make sure you know what commands you are running and how they work. And (insert disclaimer here). You Have Been Warned.
(I got most of the off of a google search, so I can't claim them as "my own.")
IMPORTANT!!!!!!
* - use with ridiculously extreme caution!
Commands Regarding Files:
ls
IMPORTANT!!!!!!
ls
