Root link2sd issue.
ok so im rooted ya ya fun easy stuff got rid of bloat and themed with GO sd card partitioned but having an issue with link2sd. it isnt linking at all it sits on the moving to sd screen. never had an issue with it before till now hmmm any suggestions? and by the way does anyone know what ever happened to darktremors apps2sd that was amazing
What type of partition did you use. Also try, remove anything from the card you don't want to lose. Wipe the hole card like new. Then repartition, for the new partition use fat32. Remember both set to primary. PM me if you need anything. I'm using mini partition magic.
