Root Link2SD question
efeigenbaum
I am pulling my hair out here. I have set up a 2nd partition on my card, formatted as FAT32, set as primary but Link2SD won't recognize it. What am I doing wrong? ARGHHHHHHH!
Scratch that, I figured it out.
I never figured out Links2SD.
But i have apps2sd. :D
You need to partition you card. Using CWM, make a 512 or so ext2 partition on you card and reboot. When you go into Link2SD for the first time, it will detect the ext2 partition and create the scripts. You reboot once again. The next time you go into Link2SD, you are ready to start moving apps to your SD.
or you can move apps using the app moving in cm6/7
