FirebirdStud Android Enthusiast May 22, 2011 #1 I've played around with it quite a bit, but I can't figure out how to accomplish this? Help please?
trophynuts Extreme Android User May 22, 2011 #2 go to a contact, go into edit mode, hit your menu key again and select join.
bigshotproducer Android Enthusiast May 22, 2011 #3 I had that problem too...it changed from Froyo. They've added an extra step. Here ya go. Pick your contact(make sure it's not a facebook one) >Options>Edit Contact>*Options Again*>Then you'll see Join Good Luck!
ZackyZombieface Member May 30, 2011 #5 I was just about to post a thread about this. Glad I used the search feature. Thanks for posting a solution!
