Using this thread:
http://androidforums.com/all-things-root-droid/136508-guide-all-things-root-related.html
And I'm on step 6.
6.) Download and install the correct motorola drivers for your windows machine (32 for XP, 32 or 64 for Vista depending on Vista version)
32-bit drivers
64-bit drivers
I'm on Windows 7 32 bit. After going to the supplied link for 32 bit, I am placed here:
http://androidforums.com/all-things-root-droid/82742-guide-all-things-root-related.html
Thinking this thread is the same, I scrolled down to step 6 on the NEW thread and clicked on it only to be redirected to the same page.
Looking at the link I see you use a redirect to get me there, taking off the redirect leaves me with:
direct.motorola.com/hellomoto/Common/Drivers%2520and%2520Plug%2520ins/USB_Drivers_32_bit_4.2.0.zip
Which leads me to a 404.
Where are these drivers?
EDIT: Found these on youtube *groan*. Anyone confirm?
http://www.mediafire.com/?4nydaqzjrni
Also it stated only for xp/vista 32bit. I assume windows 7 32bit is also fine?
And I'm on step 6.
32-bit drivers
64-bit drivers
